Fiche technique du Sony FX2
(réel) Environ 90 min (viseur) / Environ 100 min (écran LCD) min
Capteur
33 millions de pixels
Carte mémoire
SDXC UHS-I/UHS-II ou CFexpress Type A
Catégorie
pro
Cible
Plein Format ''
Compression
HEVC / XAVC LONG-GOP XAVC All Intra
Date de commercialisation
Juillet 2025
Dimensions
129,7 x 77,8 x 103,7 mm
Divers
Processeur d’image BIONZ XR. Prix : 3200€ pour le boitier seul et 3700€ en kit avec la poignée.
Ecran taille / résolution
3 '' - 1,40 Mp px
Enreg. audio manuel
Oui
Enregistrement
(XAVC HS 4K)
3840 x 2160 (4:2:0, 10 bits) (environ) : 59.94p (150 Mbit/s / 75 Mbit/s / 45 Mbit/s), 23.98p (100 Mbit/s / 50 Mbit/s / 30 Mbit/s), 50p (150 Mbit/s / 75 Mbit/s / 45 Mbit/s), 3840 x 2160 (4:2:2, 10 bits) (environ) : 59.94p (200 Mbit/s / 100 Mbit/s), 23.98p (100 Mbit/s / 50 Mbit/s), 50p (200 Mbit/s / 100 Mbit/s)
(XAVC S 4K)
3840 x 2160 (4:2:0, 8 bits) (environ) : 59.94p (150 Mbit/s), 29.97p (100 Mbit/s / 60 Mbit/s), 23.98p (100 Mbit/s / 60 Mbit/s), 50p (150 Mbit/s), 25p (100 Mbit/s / 60 Mbit/s), 3840 x 2160 (4:2:2, 10 bits) (environ) : 59.94p (200 Mbit/s), 29.97p (140 Mbit/s), 23.98p (100 Mbit/s), 50p (200 Mbit/s), 25p (140 Mbit/s)
(XAVC S HD)
1920 x 1080 (4:2:0, 8 bits) (env.) : 119.88p (100 Mbit/s / 60 Mbit/s), 59.94(50 Mbit/s / 25 Mbit/s), 29.97p (50 Mbit/s / 16 Mbit/s), 23.98p (50 Mbit/s), 100p (100 Mbit/s / 60 Mbit/s), 50p (50 Mbit/s / 25 Mbit/s), 25p (50 Mbit/s / 16 Mbits/s), 1920 x 1080 (4:2:2, 10 bits) (env.) : 59.94p (50 Mbit/s), 29.97p (50 Mbit/s), 23.98p (50 Mbit/s), 50p (50 Mbit/s), 25p (50 Mbit/s)
(XAVC S-I 4K)
3840 x 2160 (4:2:2, 10 bits) (environ) : 59.94p (600 Mbit/s), 29.97p (300 Mbit/s), 23.98p (240 Mbit/s), 50p (50 Mbit/s), 25p (250 Mbit/s)
(XAVC S-I DCI4K)
4096 x 2160 (4:2:2, 10 bits) (environ) : 59.94p (600 Mbit/s), 29.97p (300 Mbit/s), 23.98p (240 Mbit/s), 50p (500 Mbit/s), 25p (250 Mbit/s), 24.00p (240 Mbit/s)
(XAVC S-I HD)
1920 x 1080 (4:2:2, 10 bits) (environ) : 59.94p (222 Mbit/s), 29.97p (111 Mbit/s), 23.98p (89 Mbit/s), 50p (185 Mbit/s), 25p (93 Mbit/s)
Entrée micro mini-jack
Oui
Entrées / Sorties diverses
Entrées XLR
(option) oui (x2)
Equivalent 35mm en vidéo
(dépend de l'objectif)
Etanche
- (tropicalisé)
Focales vidéo
(dépend de l'objectif) mm
Griffe
Oui
Logiciel
Catalyst Browse / Catalyst Prepare + Monitor & Control
Modèles de la même gamme
Ouverture
Poids nu (ou complet)
594 (679 ou 890) g
Prix fabricant
3200 € ou 3700 € TTC Euros
Résolution photo maxi
7032 x 3958 pixels
Résolution vidéo
4K DCI, UHD et HD
Sensibilité mode Nuit/Normal
double base ISO de 800 ISO et 4000 ISO lux
Sortie casque
Oui
Sortie HD-SDI
Sortie micro-USB ou mini-USB
USB 3.2 type-C
Sortie Mini (micro) HDMI
HDMI type-A
Sortie multi / AV
Oui
Stabilisateur
capteur + électronique
Support
SD / SD ou CFexpress Type A
Torche
Viseur / Taille / Résolution
viseur couleurs 0,5'' (1,3cm) de 3,68 millions
Wi-Fi / NFC / GPS
Oui / Oui / Oui
Zoom optique
